Build our own linux distribution using SUSE Studio?
Does any one know how to use suse studio ?
Is there any specific tool available for that ?
If available please provide the link of that?
Suse studio is a web based interface where you can customize your own Linux. Here, In the site you will have an option to choose what type of Linux you are looking into. Then, you need to choose in what format you want this Linux to be used like iso image, usb bootable format etc. Then it will ask choose the package list that you want to install in your Linux distribution. Finally, you can build your own Linux if everything works fine. There are no specific tools available for this suse studio. Rather we need to use a web based interface for doing this.
You can login to this site using your FaceBook account.
