Build a template using html and flash
HTML is the programming language and it can be used to make different template. You can use both hypertext mark-up language and also adobe flash to make templates. In order to make templates using html go to the following link.
This link will guide you bitterly for making templates, as it contain list of different useful tags.
When we talk about adobe flash, obviously you need to add code for the template and need to follow other instructions.
So refer to the link below to get stepwise instruction on making template in adobe flash.
Hope your query is resolved and now you will be able to make templates.
Actually, to use a template or an HTML template, you don’t necessarily create it manually.
You can use a program such as Artisteer to generate your own unique HTML template which you can then use on your web site. With this, you can create or design your own HTML template and then use it on your website without having to go through that tedious part of manually designing and constructing an HTML page and creating a separate CSS and JavaScript files.
With an HTML template, you have an instant webpage with just a few clicks using the software.
There are many HTML generators or creators that can be downloaded from the web and one of them is Artisteer.
It is a webpage design software where you can create DotNetNuke, WordPress, Blogger, HTML, Joomla, and Drupal templates. I’ve already used it just to see what the final output looks like and they have great designs to choose from.
You can download the latest version, Artisteer 4.1 for Windows.
Hi fellows, your recommendation helped me to widen my domain of knowledge. Acquiring knowledge from your comments I have got idea that with Artisteer I can create or design my own HTML template as well with an HTML template, I have an instant webpage through just a few clicks utilizing the software. You provided other information and downloading link was helpful too, after downloading the latest version, Artisteer 4.1 for Windows now, I am able to make a template using HTML. To Sharath, a big thanks to you for providing great information about flash and I’ve learned something new about HTML. Thanks fellows, for your understandable info about what I really needed to know.
