Build a website with php and SQL server
Hy,
You are interested to make a website by using PHP and SQL. You need to have so much experience about PHP coding and scripts for build a website. If you have knowledge about that, then you can try to make website by choose a best template. But if you don’t have any knowledge about if then you should read and watch tutorial about PHP. After complete making website you should add it in your hosting. PHP is not so difficult to learn if you will give so much attention for that or if you can practice regularly then you might success.
I hope you are now clear about this matter
Thanks
You need to know PHP in depth before embarking upon making a website on it. It is a server-side programming language that makes the web pages more interactive, eye catching and user friendly that the web pages made on HTML and other languages. It is an open source, so it is cheaper to use than its contemporaries.
Yes, it is true. Before you can create a website that uses PHP instead of HTML pages, you must first be knowledgeable in creating web pages using PHP. If you are new to PHP programming and you are keen to learn how to create program codes, scripts, or web pages using PHP, then W3Schools will help you. PHP is a powerful tool for making interactive and dynamic web pages and it is the widely used, free, and efficient alternative to competitors such as the ASP of Microsoft.
W3Schools is the world’s largest web development site where you can learn different web programming tools that you can use on your website. Here are some of the PHP commands that you can learn:
PHP Basic
PHP Advanced
To learn more about PHP and to start your online tutorial, do visit W3Schools.net | PHP Tutorial.
Notifications
