Built In webcam doesn’t work. [Acer aspire 5517 ]
Solving built-in webcam issues:
If your built-in camera does not work on Skype, check first if the camera is really working. Click Start, All Programs, Acer Crystal Eye webcam, and then select Acer Crystal Eye webcam. The application should start the camera and you will see yourself on the screen. If you don’t see Acer Crystal Eye webcam in the Start menu listed under All Programs then the built-in camera maybe is not yet installed.
To use the built-in camera, you need to install the webcam software. Depending on your operating system, download the appropriate version for your computer. Download one of the following webcam drivers for Acer Aspire 5517:
There is no compatible camera driver for 64-bit Microsoft Windows 7. Also, Microsoft Windows 8 or higher is not supported. There are no drivers compatible for Microsoft Windows 8 or higher.
