Bulgarian Language for iPhone 2G
I use iPhone 2G with firmware 2.1 and I need a Bulgarian Language. What application I can use and how to install it?
Hello
To get Bulgarian language on you iPhone 2G with firmware 2.1 you need to do few simple things. First go at these page :Â http://www.iclarified.com/750/where-to-download-iphone-firmware-files-from.
On that page you chose your iPhone model. Example 2.0 (2G) iPhone… ispw file . Download file for your iPhone. Extract it. Put it in your iPhone and restore it. Its way simply.  Just read carefuly and proceed the restore procedure. Please be careful where you click because you may screw your phone. Also you can go at your provider and ask him to install it. After you complete that you will have fully installed Bulgarian language on your own iPhone.
 I hope i helped to you
