Burn mp4 to vcd player correctly
I have a problem on how to burn MP4 to VCD Player. Every time I try, the process starts before I select the songs to burn but when I halt the process and start again, I say the CD has data and that goes to waste since it is not rewritable. How should I do this without wasting many VCDs?
Thank you.
Best Answer by Cantu William
Answered By 0 points N/A #166769
Hello
You should consider using popular burning applications like Nero or Ashampoo. Those tools are checked and they work so you should stick to them. Using Nero or Ashampoo you can select whole bunch of options before burning your files. Also you can select which files you to burn and which speed to use.
You can use following links to find those applications:
Nero: http://ccm.net/download/download-1244-nero
Ashampoo: http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Answered By 5 points N/A #166770
Hi there,
It's really an easy solution, MP4 format files are very ideal for storing videos on computer , internet, MP3 devices. However, the software that burns video compact disc (vcd) cannot read or support MP4 format file. That's why you can't burn any MP4 file to VCD. In order to do that you have to convert MP4 file type to MPEG type so that the burner can read this type of file. To convert MP4 to MPEG you can use any converter you want.
Good day.
