Burn Process failed at 8x
Hi experts,
I found the above error message when I tried to use Nero software. Need to solve it.
Please help.
Nero Burning ROM
Burn process failed at 8x (11.080 KB/s)
OK
Hi experts,
Please help.
Nero Burning ROM
OK
Hallo Carol,
Such an error occurs because of one of the following two reasons:
Carl
Dear User,
Check these,
·Try burning the same files in to another disc.
·Try using another Application for burning purposes , so you can make sure and reinstall Nero
·Try changing your burning speed
· If none of the above doesn’t work. This may well be a hardware related problem.
So Verify this with your hardware provider
Thank you
Notifications
