Business process error on the Microsoft Dynamics CRM server
I am trying to debug plugin registered for online version and installed Plugin Pro-filer in the plugin registration Too. I registered the plugin and step on the Microsoft Dynamics CRM server. I performed the operation in CRM that causes the plug in to run but the plugin showed an exception and the Business Process Error dialogue displayed.
Unexpected exception from plug-in (Execute): CrmOnlineErrorLogging.TestPlugins: System Exception: Error logging
Answered By 0 points N/A #192027
There are two ways to resolve this error.
*Change the Click Dimensions plug-in's isolation mode to None:
Using the plug-i registration tool, manually update the plug-in so that it is not using the Sandbox isolation mode (as indicated in he image below)
If the Click Dimensions solutions is Uninstalled and reinstalled, you must repeat this step or configure the proper permission for the Sandbox processing service logon account.
* Configure the Correct permission for the Sandbox Processing Service logon account:
This is the recommended approach. Ensure that the login account for the Sandbox processing service on the CRM server has the correct permission as identified in these articles:
https://technet.microsoft.com/en-us/library/gg197608.aspx
https://technet.microsoft.com/en-us/eus/library/hh699825.aspx
