I created a new page on our website. Now I want to send the link to my co-employee. How can I make the link a colorful button instead of an ordinary URL link only?
wengroa
Button link when sending email
I send emails to my co-workers when I create a new page in our website. Instead of sending the URL link,
How can I turn the link into a colorful button?
You can use "rainbow links script".  You can download the rainbow script, then extract it into a java file by using the extractor software, such as; winzip or WinRAR. Then upload the file that you have that you have extracted into the server, which you usually use to save the file. After uploading it, take the URL of the file and make the URL link like this( sample only):
They create a code like this:
<Script src=''http://www.dynamicdrive.com/dynamicindex5/rainbow.js''/>
Then after that, log in into blogger using your ID. Then click the layout and then click "Edit HTML " tab and find this code </head>. Then after, save the script code above the </head>. Finally after that click on "SAVE TEMPLATE" BUTTON AND DONE.
After doing all that, you can now view your blog and put the mouse on it.
If the link has a wink and the color changer automatically, it means it works well.
