Buy some computer hardware and software
Hello, I would like to buy some computer hardware and software. Is there anything I should know beforehand? What are the technological, organizational or management issues I should consider. Thank you.
Hello There!
Buying equipments especially if you intend to use it for a long time takes a lot of decision making. Have a checklist like this:
1. How much budget do you have?Â
  – make sure that you have the right resources before buying anything.
2. What kind of hardware?
  – Is it a RAM? VideoCard? etc. before buying things like these, make sure you have all the information you need. If you are to buy a VideoCard for example; do you intend to play (buy nvidia/amd)? Watch movies (buy intel hd graphics)?Â
3. What kind of software?
  – Is the software useful to you? Is the rating of the software good? Some softwares out there are a bunch of crap. Others may harm your computer so choose wisely.
4. Research.
  – Make sure you research some information about the product.
Those are some tips/considerations before buying any hardware/software in the market. You may add since I am limited to those options only.
I hope I helped you.
Good Day!
There are lots of thing you should consider before buying computer hardware and software. Most of the factors are depending on your requirements.
First you should identify your requirements. Like what kind of work you are going to do using your new hardware. (EX: Video Editing, Gaming, Internet Browsing, Software Development….)
If you are going to buy hardware and software to your company then find something matching to you organizational requirements.
Then you should identify type and brand of hardware you require and you should consider price of that hardware.
Another important factor is finding a reliable vendor to buy your hardware & software. Because quality and after sales services are really important in these days.
Every time buy original hardware and check for the warranty of your hardware because warranty makes most important concern when buying computer peripherals.
Also buy original software which is matching to your hardware performance.
Thank You.
Manoj DT
