Daphne
Posted on - 11/18/2011
Does Easy BUS Software fit and suited for any variety of users? My question is, whether there’s a need for all-in-one and one-time, to buy and acquire Easy BUS software? Is it better to purchase the software separately? Or should I buy it altogether? Thanks!
Buying and acquiring Easy Bus software
No, the software doesn’t vary with the user. You have to select the right one that's suited for you. The bundle package will not be good. Just think a little bit do you purchase all the same thing from one brand. If you don’t want so why? It may reduce the cost of your total pricing and also helpful to work within a same roof.but some features you may not find in the bundle which you may need
Hi there user,
Grab only one (1), but you have to make sure that you fully understand its features. Getting all in one is like buying a bulk of computers, it’ll take time to familiarize or configure each unit. Especially you’re alone doing it. What's important here is that you are aware of its system features. Scan it well with your eyes; browse it with your fingers. You may check the facts here http://www.easybus.com/faq?to=support
Thank you for posting.
Best regards,
