Buying Dell Latitude E4300 Screen Online.
The LCD screen of my laptop has shattered to pieces after I hit with the ball. I want to buy Dell Latitude e4300 screen online. Where can I get the best one?
There are many places online where you can get your hands on the E4300 screen. Amazon sells the genuine version of screen at Rs. 3383, ebay sell it at Rs 2500. The warranty and the sellers are the cause of the difference. You should contact the customer service if you don’t want any hassle for yourself. They will find the original screen and replace it for you. There are tutorials which show you the right way to remove and install the screen.
If you want to buy an LCD screen replacement for your Dell Latitude E4300 laptop, make sure you know the actual screen size so it won’t be hard to buy a screen replacement because the LCD screen replacements that can be bought comes in sizes and you need to be accurate so it fits in your laptop. Anyway, you can check the following Dell Latitude E4300 LCD screen replacements:
Notifications
