Error on buying iphoto book
Hello Greetings,
Hello Greetings,
In the event you accept the slip inform, you will be mechanically administered to a page in your book. From there, click on the underlying level choice, to see which underpinning level you have chosen and update it if indispensable.
To institute the most recent form of iPhoto, or see if revamped programming is ready for your PC, decide on Software Updates from the Apple menu.
Respects.
Hi Garrykirsten,
Maybe you chose Palm Tree background option. In iPhoto, you can choose to show grey background page to not get this error message. The error message appears because the Palm Tree background option, is made to use your own photo as the background, not a gray background.
So the solution is to choose different background. You should be redirected to click on this option. You can choose black or white background, gray background – theme Contemporary or theme Picture Book themes in iPhoto 7.1.
So you have to go through all photos and to check the background.
Thank you,
Tina
