Buying new monitor and considering its features
Hi!
I would like to purchase HP Pavilion 23xw 23-inch IPS LED. I want to know the specifications of this monitor? What are the best features with this monitor? How long it will be covered by its warranty? What are the peripherals including in the box package? What are the ports available to connect it with my cable box and desktop computer? Can I use it as my secondary screen in my laptop? How much will it cost if I buy this monitor? Is this my best option or do you have any suggestions? Thank you!
Answered By 0 points N/A #165986
        The monitor we are using right now probably came and bundled with desktop PC. It may be back we are considered 1240 by 1240 which is considered as a high resolution. When we spend huge parts looking everyday better we buy LCD monitor.
        The price range may be varied as to the quality of the system panel. Basically the monitor size depends on market value for example Viewsonic VA2251m-TAA price on Ebay is $105.00 are no frill model.
         The monitor which is 22 inch cost is around $160 to $180. So based on monitor quality and performance price might be varied.
