Buying a software for registry cleaning
I am a normal user on a computer, meaning I browse the net, my kids would play games, etc. Lately I noticed that my PC performance is somewhat sluggish. Also a few notification errors have popped-up. I am thinking of buying a software for registry cleaning. Do you have any suggestions on what brand should I buy?
Thank you!
Answered By 0 points N/A #104224
There are many third party softwares for registry cleaning that you can find for free on the internet and I do not see the need to for spending a lot on them by buying from a shop. I will recommend for you one that is called ccleaner. You will just need to go to Google and search for it, download it for free and install it and then use it for registry cleaning.
But before even you do that, you can use the disk cleanup utility that is available on your computer to empty any files that are taking up space on your computer and they are not necessary.
Click start on your computer and then type disk cleanup in the search box.
Press enter on your keyboard to open disk cleanup.
In the disk cleanup, check all the boxes for the files that you want to cleanup and then click OK.
-Keegan Robb
