C code that terminates the program
What kind of code I should use on C programing that allows the user to type a certain letter to terminate the program and does not terminate it until it is the same letter the programmer asks.?
The following code snippet asks for a character which is known for exit. and then enters a loop where it asks for characters one by one and checks for necessary exit value. If found, it exits.
#include<stdio.h>
#include<conio.h>
void main(){
char exitchar,newchar;
printf("Enter the character for exit.");
scanf("%c",exitchar); //The character to exit is given as input
while ((newchar=getch())!=exitchar){ //getch() accepts a character and first places in newchar then checks for exit.
printf("%c",newchar); //print on screen
You may write the equivalent code
void main(){
while (1){
newchar=getch();
If (newchar==exitchar)
return(0); //If the exitcharacter is found.
else
Hello Ulysses Arredonto,
These are the working snippets for your query which shows the requirements you desire.
Try these and sort your program as you want.
#include<conio.h>
#include<stdio.h>
void main(void) {
char e,n;
printf ("Enter the character for exit: ");
scanf ("%c", e); // here e stores the exit character
while ((n=getch())!=e) { // the value is stored in n by getch() and checks for the exit value
printf ("%c",n); // values are shown on the screen until the e entered
This is the code in C++ environment which might be helpful to you …
#include<conio.h>
#include<iostream.h>
#include<stdio.h>
void main(void) {
char e,n;
cout << "Enter the character for exit: ";
cin >> e; // here e stores the exit character
cout << n; // values are shown on the screen until the e entered
Hope this will help you in your problem.
Thank you
Emon Asejo
I tried this and it worked.
#include<conio.h>
#include<stdio.h>
void main(void) {
char e,n;
#include<conio.h>
#include<stdio.h>
void main(void) {
char e,n;
THANK YOU FOR THE HELP!!
