C Objective: Unable to Login
Hi! I have downloaded the sample of C Objective but I cannot login successfully even with the correct credentials. Is there any other way to access it? Kindly provide me solution on this matter. Thank You!
Error:
Unable to login
Please check your box.net developer account credentials. Either the application key is invalid or it does not have permission to call the direct-login method. Please contact [email protected]
