External hard disk has become a mandatory requirement today, Because the capacity of my hard disk is already full, then, I tried to defrag my external hard disk. But after I de-fragmented the hard disk's external cable, the cable had ripped its own damaged and broken connections.
My question is, is it common to have a missing data after the incident? Since a lot of data were inside the disk, I need to recover those data.
What do you think will help me solve this problem?
Cables External hard disks disconnected during defrag
Hello Ruth C,
I totally understand the dilemma you are facing right now regarding the recovery of your lost files from your damaged external drive. I would like to provide you with proven solutions that I utilized when I encountered a problem with damaged hard drives for recovery. I could not, however, guarantee that all the files lost can be recovered successfully since these solutions I offered are user-based and will not entail an outrageous fee. Also, I know that you are not prepared to pay if you will submit the external hard drive to professional data recovery companies.
Hopefully, I have provided you with the proper information before proceeding and indulging into the solutions I have prepared for you. I have also included some reading materials from the website for you to read and get a better understanding on how your data was lost . This will help you a lot so that you will be more prepared for it in the future.
Please feel free to reply to other questions you may have with regards to your ongoing data loss issue.
If the defragmentation of the external hard drive completed successfully, there should be no problem with your data in the external hard drive. They will remain safe in there as long as the hard drive itself is not damaged. If the only problem is with the USB cable that got ripped off, you just need to replace it with a new one.
The USB cable used in an external hard drive is normally a microUSB cable which is a cable with a standard USB connector on one end and a microUSB connector on the other end. You can actually just buy any cable with the same specification like this THREE Pack USB to Micro USB Sync Cable on eBay for $7.50.
1....
