For CADWorx to function, this system needs to be updated
Hi there,
I have uninstalled AutoCAD 2014 because I have updated my Windows 7 and it messed up the program. After inserting the CD with AutoCAD 2014 and click the Next button this error appeared. Update needed- I don’t know what updates it needs and someone can help me please with this ? There is no update available to install. How can I solve this ?
Thank you !
The custom entity fix done for AutoCAD 2014 has not been applied to the AutoCAD 2014 on this machine. For CADWorx to function , this system needs to be updated with the latest fixes for AutoCAD 2014 on this machine. For CADWorx to function, this system needs to be updated with the latest fixes for AutoCAD 2014. Go to www.autodesk.com to get the latest update for AutoCAD2013. Until this update is done to AutoCAD 2014, CADWorx will not function correctly.
[File to update=C:Program FilesAutodeskAutoCAD2014acdb19.dll]
[Current Version=19.1.18.0.0]
OK
