After using calculator widget I found some drawbacks of this widget.The calculator widget is almost useless. It's annoying that the window for displaying numbers is very small and I do not find any way to enlarge it, or even to scroll across it to see the entire window. Plus, there's no way to backspace over a single digit. Is there's a way to configure this widget to deal with these problems ?
CALCULATOR WIDGET IS ALMOST USELESS
Hello
You forgott to mention which operating system you are using and which calculator widget you are using so we can't help you about fixing your existing widget. But I found cool calculator widget which you can use. According to user feedback this calculator widget is very popular and easy to use. This is made for Windows 7 and I assume you are using same operating system:
Link for widget download: http://download.cnet.com/Window-Gadgets-Calculator/3000-2053_4-10757175.html
Regards.
