Calibre version 0.7.11 Error Installation
I have just installed to the latest update 7.11 and I got the following error when I tried to run the software. I can’t fix this issue without expert’s advice. Any assistance would be really appreciated so guide me with proper solution.
Bundle of thanks.
Error:
Python function terminated unexpectedly No module name stylize (Error Code: 1)
Best Answer by Wiley Kolar
Answered By 0 points N/A #176758
Make sure that you are trying to launch Calibre with Calibre-portable.exe, be sure that it is not caliber.exe. You can find Calibre-portable.exe at the top level of the Calibre Portable folder.
If this does not help you also try this:
First uninstall the caliber and then re-install it make sure that you disable your antivirus.
Answered By 15 points N/A #176759
There seems to be something wrong with either the system or with the installation of Calibre and related python dependencies.
Because as far as I know about there is no module named stylize listed anywhere for python or is used for Calibre.
You might want completely uninstall Calibre from system and clear all the temp, cache and registry of related stuff, before reinstalling or using Calibre portable.
PS. Please download a new version of Calibre e-book management 1.10 if possible and import you library it's much more bug free.
