Call Of Duty- Module Failed to Load?
Posted on - 10/04/2011
RegSvr32 Error
The module “d3d9_37.dll” failed to load.
Make sure the binary is stored at the specified path or
debug it to check for problems with the binary or
dependent .DLL files.
The specified module could not be found.
OK
I am trying to play Call of Duty on my laptop. I keep getting an error message that the module failed to load. I need to fix this as soon as possible! Does anyone know what is going on? I am running on Windows 7 with 64 bit, if that helps any. Error message reads as above. I appreciate all advice I can get.
Thanks!
