Call Recorder for Skype for Mac
How do I put the call recorder control menu in hidden mode? I unchecked the boxes in the recording tab, but the control menu still pops up every time I make a call. I do not want it there at all.
Thanks
Thanks
Dear,
You didn't mention which recorder you are using for recording Skype calls. However your recorder must have the stealth mode or parental mode control which will disable the pop up.Â
There is a call recorder named Ath Tek Video call recorder. It has the stealth mode for parental control. So no popup. Please refer the below website:
https://secure.skype.com/calling-rates?language=en&expo365=empty
I would suggest ecamm.com's Call Recorder for Mac. It has an auto-hide feature if it is ok with you. It can also record audio and video calls and turn it into a movie. You can also share your recording into an MP3 format.
You can try it first by going here http://www.ecamm.com/mac/callrecorder/ or if you want to buy it comes with a $19.95 price tag.
Hope this helps.
