Call recording option on Skype
How to make conference call on Skype?
Is there any feature option to record call like chat history is recorded?
You can create group for conference call. Open your Skype, at the place of your contact list, below you fine ‘add contact’ and beside this you see group. Click the group, a window appears. Drag and drop contacts from list to that window. You group has created. Now go for either make a call to that group or sending IMs.
You can also add people to one call. Make a call to anyone. Now if you want to add people in your call. You will see the plus (+) button beside your end call button. Click then button, a window appears with the list of your online contacts. Select contacts from there.
You need to install another application for call recording. Go to tools tab and then click on apps and get apps. A web page appears. Download an app named as Pamela. This will provide you call recording and video recording services.
URL: https://secure.skype.com/calling-rates?language=en&expo365=empty
Conference calling is when making two or more calls simultaneously. Skype allows calling up to 25 people at the same time for free, no matter where they are in the world. To start, simply click Contacts > Create New Group from the menu bar.
From the Contacts tab, click the contact/person you want to include and drag it into the Group Area (a box you can see in the right corner). Do this to the other contacts you wish to add in the conference call. When you’re done, click the Call Group button and then you’re ready to go.
As for recording calls, Skype doesn’t have an inherent support to record conversations yet. However, there are add-ons you can procure to make this possible. While some requires you to purchase them, some are totally for free. PrettyMay for example is a popular add-on that you can download for free. However, there is a time limit of 30 minutes.
To download, just go to http://www.prettymay.net/download.htm
Good luck!
Latest Skype supports the full recording method with good quality. Just follow the steps described here.
Notifications
