Ella S Bunn
Posted on - 08/15/2014
I just installed on my PC CamStudio and this is the error when I want to open the program. The installer is downloaded from a trusted website and the installer is fully compatible with my OS. Any solution ? Can anyone tell me please why I cannot open CamStudio ?
Thanks !
C:programsCamStudio 2.6bRecorder.exe.
Cam Studio error during opening the program after the updates
The C++ runtime components (true) have missed from your machine. Uninstall Microsoft Visual C++ (existing) Redistributable Package. Install the updated Redistributable Package (Microsoft Visual C++ 2010). It will help you. Â
The machine is missing the correct C++ runtime components for your type of system. (x86 or x64).
You can uninstall any existing Microsoft Visual C++ Redistributable Package and install the latest Microsoft Visual C++ 2010 Redistributable Package and check if it helps.
Step 1:Â
Uninstall the package:
·        Open Programs and Features.
·        From the list, find Microsoft Visual C++ Redistributable Package and click on it.
·        Click Uninstall at the top of the list.
Step 2:Â
Download the latest package:
Step 3:Â
Install the recent package.
