Hello everybody,
I have HP Slate 7 HD 3404 and it was working fine.
But, from the last few weeks I am facing a lot of issues. I have tried to upgrade it, but always uses it to fail with errors. I lost patience and did a factory reset and it went fine. After that I am able to upgrade it to 4.2.2 kernel 3.4.5 successfully. I felt happy, but I got a new problem. I lost my camera app. I tried to download again but I couldn't do it.
Can somebody help me out here. Thanks in advance!
Camera app gone after upgrading HP Slate
Hello Jesse,
Did you try to contact customer support. Sometimes the kernel update has issues and need to be reported. Check Google play for new camera app. Maybe the old one is removed from the store.
Try installing app like Instagram, if they are not able to figure out your camera , The issue is with hardware and you need to contact customer support. They will repair it for you or will provide a new one.
Scurlock Ward
If you need a camera app for your HP Slate 7 HD 3404 tablet, any camera app you can download on Google Play should do. Try Camera for hp. This app requires Android 4.1 Jelly Bean and higher which makes your tablet very much compatible because it runs on Android 4.2 Jelly Bean. You can also try the official camera app from HP called HP Smart.
Unfortunately, the latest version requires a much newer version, Android 6.0 Marshmallow and higher. Still, try visiting this link to see if a version for your model is available. For other camera apps that may be compatible with your tablet, go to Android camera apps.
To access your tablet on your computer, go to Software and drivers for HP Slate 7 HD 3404ex Tablet to download the driver. Here, click “Choose a different OS” and select the correct Android version your device is using. If this is not the correct model of your device, click “Choose a different product” and locate your product.
