Cameyo says new manifest bigger than original
Hello Tech Professional,
Cameyo helps me a lot in carrying all my works with me wherever I want. Now I am stuck up with a warning message, when I carried my files with virtual application I am able to setup only in some machines. For some I am getting a message, why I am getting warning message all of a sudden? It means Cameyo got corrupted? Please guide me resolve this problem.
Error:
Warning
New manifest bigger than original: C:TempAppPackagerResManifest.PE (833 -> 846)
Answered By 590495 points N/A #186025
If you were only able to run the virtual application on selected computers and the others generated an error, try going back to the computers where it failed and clean the temporary files. Sometimes the system fails to update or replace the temporary files and when a program runs it somewhat creates a conflict preventing it from successfully opening.
So what you can do is, go back to one of the computers where it failed. Then on that computer, click Start, All Programs, Accessories, System Tools, and select Disk Cleanup. Or just open Disk Cleanup if these sections are not available on the computer. Select drive C and click OK. Check “Temporary files” and click OK.
Wait for it to finish and restart the computer. Start the virtual application again and see if it works. If you are still having a problem starting the virtual application try running it as administrator. This is a pretty common error with programs starting from Microsoft Windows Vista onwards. Right-click on your virtual application and select Properties. Select Compatibility tab, check “Run this program as an administrator”, and click OK.
Run the program again and see if it works. If you are using an old version, download the latest version from Cameyo 2.6.1191 Download.
