Hello, I have just upgraded my Windows XP to Windows 7. I have MacBook Pro Intel Core 2 Duo with 4GHz and 2MB RAM. I am going to upgrade it later to 4MB. After I have upgraded my operating system to Windows 7, my Camp Tune for Mac didn’t work and I could not be able to resize my partition. Please send me suggestions on how to resize my partitions. My Windows 7 do not have a boot camp because I don’t use XP anymore. Is there something I need to do with this? Please help me. Thanks a lot.
Camp Tune Stopped Working after Upgrading to Windows 7
You can use the computer management option that is available on the windows operating system to create partitions on your computer. But if you have already tried that and it did not work, then you will need to try using a third party application called partition Logic.
It is a free hard disk partitioning and data management tool, and that means that you can download it for free online. With partition logic, you will be able to create, delete, format, defragment, resize, and move partitions and modify their attributes as you wish. One of the very important feature that is has is its ability to copy entire hard disks from one to another. See below a screenshot of partition logic in action:
-Clair Charles
