Campaign management in excel interface lets to edit campaigns
Hello expert,Â
My friend told me campaign management in the Excel interface lets to edit campaigns and create new campaigns.
Is it possible on MS Excel 2007?
Hello expert,Â
The campaign management interface allows users to edit existing campaigns and create new campaigns using Microsoft Excel (XLS) files. This feature only works with XLS format files i.e Microsoft Excel 97 to 2003. It doesn't support XLSX, XLSM, XLSB or other such formats In Excel 2007 the default format is XLSX. So you can use it in Excel 2007, if you save files using "Excel 97-2003 workbook" instead of the default .xlsx. To save Excel 2007 in XLS format, while saving file click on Save as type and select Excel 97-2003 workbook (*.xls)
Regards, Laz Zebbena
