I have used CamStudio many times in the past and I really like it I recently installed it again so I could produce a screen case, however when I press the stop button I get the following error message ( https://www.flickr.com/photos/37936322@N03/6878556774/ )
Is there any reason for this, I have installed all the latest codecs.
Browser:Firefox 11.0
System: Windows 7 Ultimate SP1 32-bit
Thanks in advance.
Camstudio problems need some help.
That’s why it never worked on your machine. Maybe you upgraded your machine’s operating system that’s why the application no longer works on your computer. This application doesn’t support Windows 7 platform. CamStudio Free Streaming Video Software works only with Windows XP and with Windows Vista regardless of their edition and the Service Pack they are running on. If you still want to use this application, you might want to downgrade your operating system to your previous platform to make this work again.
But if not, there is an alternative program that you can use as replacement for CamStudio Free Streaming Video Software. You can install BB FlashBack Express which works with Windows XP, Windows Vista, and Windows 7. To download and install BB FlashBack Express, you may visit Blueberry software.
