Camtasia Studio has stopped working
While the Camtasia was loading suddenly this error appeared and closed the program. Because of this crash Camtasia is not working at all. Please help me to fix this error without reinstalling the program. What was the cause of this error ?
Thanks !
Camtasia Studio
Windows is checking for a solution to the problem…
Cancel
Answered By 590495 points N/A #176508
If you normally use Camtasia Studio or have used it before but not regularly, close the application and restart the computer. Start Camtasia Studio again and see if it works. If this is a fresh installation, make sure you meet all the requirements and you install the required component. Camtasia Studio supports Windows Vista, Windows 7, and Windows 8.
If you have a Windows XP, maybe an older version will work for you but not the latest version. You need to install Microsoft .NET Framework 4.0 which I think is already included in the package and will be installed automatically. To check if it is installed on your computer, click Start, Control Panel and select Add or Remove Programs.
In the list of installed software, scroll down and find Microsoft .NET Framework 4.0. If you have several Microsoft .NET Framework installed on your computer, check if version 4.0 is installed. Like for example me, I have several versions of Microsoft .NET Framework on my computer. Installing the latest version sometimes doesn’t help because there are applications that require a specific version. See image.
In case version 4.0 is not installed on your computer, download and install Microsoft .NET Framework 4.0. This is the web installer. If you want a standalone installer for offline installation, download and install Microsoft .NET Framework 4.0 Standalone Installer.
