Can 3D Bomberman classic mobile games be played on a sumsungR5830?
mikekay 0 points N/APosted on - 10/03/2012
I have downloaded one of the bomberman classic mobile games, 3D BOMBERMAN ATOMIC, onto my java enabled Chinese double line phone, Samsung r5830. it launches well but when it comes to playing it, the touch screen becomes insensitive. What could be wrong?
Hello Mikekay,
Maybe your memory is low? sometimes that's the problem with games because you need to allocate a lot of memory so that the game can allow its database to save some files on your memory, so that you can play the game smoothly and with an ease. Just try upgrading your memory and try again well if the memory thingy doesn't help at all I think the game itself isn't compatible with your Samsung r5830? cause if its compatible with it, you can play to it smoothly.
If the game installed successfully on your phone and the game loads when you open it but touchscreen is not working, it means the game is not compatible with your device. Another reason for this problem is when the game is for a different screen size.
If the screen size of your phone is not compatible with the game like when the game is designed for a much smaller or bigger screen size, this incompatibility in the display makes the touchscreen function disabled. To fix the problem, just download the correct screen size of the game or download the screen size that is closer to your phone’s screen dimension.
3D Bomberman Atomic
To download the correct screen size for 3D Bomberman Atomic, go to 3D Bomberman Atomic screen size download page. The game is available in five (5) screen sizes: 128 x 160, 176 x 208, 176 x 220, 240 x 320, and 240 x 400.
1....
