joelabrame
10 points
Posted on - 11/15/2012
While using a magic memory stick for Pandora’s Battery PSP, can I do away with files from the memory stick and use it once more as a normal memory stick. Can a 512mb work with Vista? I am stuck.
Thanks for your help.Â
Hello Joel,
Yes you are able to reuse the Memory stick as normal memory stick. Memory sticks are intended for storing data. They're not strictly for you PSP device, You can even reformat it if you want to sacrifice the files or data installed in your Stick.
You can install Vista in your system, but only strictly to Home Basic only. Higher versions of Vista Environment do not support 512MB memory.
Hope this simple fact helps you
