Can 5GB of data be recovered with easy archive recovery software?
Hello all, have a fantastic day.
I am an auditor and i have to keep heavy files of client's data in soft archived form as the data is usually in GBs, i was working on a client and i stored its data in archived form in a disk which corrupted today, i really need to recover that data but i wonder if data of 5 GB can be recovered with easy archive recovery software? Please help me in this regard.
I will be waiting for your reply.
Best Answer by Jeremy J McPhail
Answered By 10 points N/A #169966
Hi Clarence K Dwyer,
May be recovered or not but what's the problem to try? Try this because there are many recover software available on websites. If you don’t want to purchase there are many free versions of software which are trial for 30 days or 15 days. So, I think you should try any one software because your files are important to you. You can use “Recuva” it has a free version and I am not saying that you will get your lost file but why you shouldn't try. You can get “Recuva” from:
http://www.piriform.com/recuva/download
Best wishes for you
Answered By 50 points N/A #169967
Hello, Clarence
Hope you are fine.
I hope you can easily recover your data by using one of the softwares.
To download click one of the links Restoration
Restoration is an easy software to use. It has a straight forward tool to recover files that were removed from the recycle bin or deleted directly  from Windows. It requires no installation. Restoration supports FAT and NTFS as well as digital cameras cards.
If it does not work you can take help from a company that is specialized in recovering data. There are some company  lists
Action Front Data Recovery
It is a specialized company that deals with many IT solutions including services of data recovery.
Hope you will get your answer.
