Can A Flash Drive Be Repaired If Accidentally Broken?
I borrowed a flash drive from my college and I think it’s not working properly. I kept it in my pocket and I am afraid it’s because of wear and tear that occurred on my part. Can a flash drive be repaired if accidentally broken?
Answered By 0 points N/A #277890
Hi, although I have not tried using a system restore for this purpose, I would suggest not to do it. This is because if there is a virus, it will in turn infect your restore points as well, causing more problems. So, remove the virus first.
I realize it might sound expensive, but please consider investing in a good antivirus software.
I suggest avast or quickheal.
Viruses nowadays are very strong and need an effective antivirus to combat it.
