Can active directory be installed in NTSERVER 4.0
Hello experts
I have a question. Is it possible to install active directory on NTSERVER 4.0? If so, then how can I do this?
Please help. Thanks.
Hello experts
To install active directory in NTSERVER 4.0 you must have the basic requirements you will need. Of course, you must have the DSClient installed. To do that, you must have its prerequisites which are Windows NT 4.0 Service Pack 6a, and Internet Explorer 4.01 or later.
Once you have installed the DSClient.exe self-extracting executable installation file it will launch the installation wizard. The Windows NT 4.0 is available for free download from http://www.microsoft.com/en-us/download/default.aspx.
To make this easier for you here is the website for Microsoft which will automatically bring you to their support page: https://support.microsoft.com/en-us/help/288358/how-to-install-the-active-directory-client-extension. This page will help you understand how to install the active directory client extension further.
