Can adobe acrobat 9 cleaner tool restore adobe settings?
I recently uninstalled adobe reader from my computer and lost my settings. Is it possible to use adobe acrobat 9 cleaner tool to recover them? Help
I have read about your problem, you cant use the adobe acrobat 9 cleaner to recover the previous settings of your adobe reader, cause the use of the adobe acrobat 9 cleaner is to help you to restore corrupted file or interrupt installation since in your case you uninstalled your adobe reader so meaning to say you cant use the adobe acrobat 9 cleaner to recover the previous adobe reader. I may suggest to you to installed again the adobe reader same version as the other one you uninstalled.
