Hi guys I want to what are the key specs of Alcatel One touch  Idol smart phone actually I read ut reviews but could not come up to the point to buy it or not and also I want a smart phone at low price that should offer memory expandable to 32 or 36 GB.So please tell me is this phone recommendable to buy and its memory is expandable or not.Thanks
Can Alcatel One Touch Idol be expanded to 36GB?
Joseph
This Alcatel smart phone's  memory is  expandable up to 36 GB. The OS system is Android 4.1 Jelly Bean.
It has some advanced features for a phone of its cost. If you need to check other specs  click on the link below: It also supports 4G
Hope this helps
Riley
Hi, the Alcatel One Touch Idol is a smart phone that offers 1GB RAM with good processing speed  and yes it is expandable to 36GB. When ever you want the phone memory to be expanded you can expand it till 36GB, quite good for Alcatel phones isn't it. It has all other good qualities that other smart phones in the market has just with a different brand name.Which makes the biggest buying difference.
