Can any camera use with the eos capture Windows 7
Hi friends
I have Samsung MV800 digital camera. I herd about the software called eos capture that can control the camera from the computer. I have windows 7 operating system and I want to know is it possible to use this software for my camera.
Thanks
Best Answer by Emil Onoon
Answered By 0 points N/A #154245
I will help to clear your concern. The software EOS capture is a photo capture utility, made for Canon EOS cameras. It helps to transfer images from Canon cameras to your computer. Your digital camera is Samsung MV800 which is incompatible with the above said software. You cannot transfer files with this software. To be able to transfer photos, please have a look at the CD/DVD that came with your camera.
Answered By 10 points N/A #154246
Almost all cameras use software and drivers to show their result to the user screen. In this case you can install the driver and software and you will be able to use the camera if it is supported by your operating system.
Smith Thompson
