Can any one help me finding Firmware for LG LHT6340
Hi Experts,
I have recently got a home theatre. Can any one help me find the appropriate LG Firmware LHT6340, which might have been missed in LG's database.
Hi Experts,
Hi!
Your question is very important to all. I have just researched and got the perfect solutions.
You should download from the original website :
http://www.gmfok.com/firmwares/home_theatre_systems/lg/lh-t6340.html
If you can not find the driver installation file then go to  http://www.gmfok.com/order.html
Register first and then order for your product.
In the installation period make sure that internet connection is available. Because setup will download the installation update files automatically .
If the problem is not resolved then contact with service provider.
Thanks
Nowell
