Is there an option in BIOS to boot from USB disk?
if i there is no option in bios of a motherboard to "boot from usb". can this option be added by upgrading the bios version? will this option work properly?
Yes you can update your current BIOS version to a new update version. Â Boot from USB is not a option for all BIOS version. If you do not have this option then you can update your BIOS version to a new Version. It will give you the option for boot from USB. Follow these steps
Hello Siam999.
It would help if you could post your motherboard brand and model so we can have a look through motherboard manufacturer's support site.
To answer you question, it is possible for options such as "boot from usb" to be one of the functionalities added by a BIOS update. Â BIOS updates are released by motherboard manufacturers for several reasons:
Again, I am not saying that the functionality that you are looking for will be added for sure in a BIOS update. Â I'm just saying that it is a possibility. Â So before you try flashing your BIOS, make sure to read the Release Notes for the BIOS to know what bug fixes or new features have been added (if any).
Hope this helps.
