Can anybody help me with fake work screen?
I was wondering if someone will help me to create a fake work screen for Windows 7? Any kind of help regarding this will be appreciated.
First of all update or install Flash Player 9 on your pc
Now go to this link http://www.readatwork.com/
Wait until full bar loaded and then search and click NZ Council Book Guest link.
Now a fake screen will appear on your desktop
All the contents on the screen will be clickable
A fake Power Point will also appear most probably 2008
ESC puts back screen to original state.
Enjoy!!
This is a very simple task to accomplish, as you will only need to print screen your current work screen first. Right click on your desktop, move to view and uncheck the show desktop icons. After that, make sure that your task bar is set to autohide then make your previous screenshot your desktop wallpaper.
