zenith keen
30 points
Posted on - 08/23/2012
I faced a weird issue, which is my ISP told me I’m using 1 mb connection which is true. But, I go through online speed test DNS, my result was 1.5 mb. So I was wondering what caused to show my speed, 50 % increased. Any kind of suggestion and help would be appreciated.
Can anybody help me with speed test DNS?
Hi friend,
I don`t think that this is an issue that you need to worry for. The DNS speed test is still an online tool, and you and me both know that some sites work and download faster than others. Probably the site where you do the test has a fast download and log time, so the DNS shows a little bit faster speed. Or maybe you should try different tests and then compare the results.
Do not worry, since your connection and speed is OK.
regards,
