Can anybody tell me how to set up Microsoft lync on n8?
Hi
I have nokia n8 mobile phone and I recently installed the Microsoft lync through the nokia suit. But I cannot set up the lync on my mobile phone. What is the reason to this and how can I solve this problem?
Thanks
Answered By 0 points N/A #149329
1.    You have to change some settings to set up lync in your mobile actually it is used to communication among group of people in your network .
2.    People in the group must installed lync to set up a network . and add or change settings of network set up section in mobile.
3.    Create a network with domain name service (DNS) settings first choose type as CNAME and hostname as lyncdiscover.preferreddomain name.com and destination as webdir.online.lync.com and ttl as 1 hour.
Hope these shall helps you
Thanks
Answered By 590495 points N/A #327341
If your organization or company uses Lync and you need to install it on your phone, you can download the Microsoft Lync 2013 app. Unfortunately, when I searched for this version on Google Play, this version is not available but instead, Lync 2010 is listed. In this case, just try downloading this version instead.
With this version, it appears there are a lot of negative feedbacks from users who are unable to log in. Another website provided a download of Microsoft Lync 2013 but when clicking it, you will be directed to Skype for Business on the Google Play store. If you want to try this version instead, download Skype for Business for Android on Google Play.
The latest version at the moment, Skype for Business for Android 6.25.0.27, requires Android 4.2 Jelly Bean and higher. It is rated 3+ and was last updated on July 29, 2019. So, this is an up-to-date version.
