Can Anyone Explain How Can You Fill Out A Pdf Form?
I want to join a new coaching centre in my city. For this, they have a form I need to fill. It is in pdf form and even though I have saved the file, I am not able to fill. Can anyone explain how can you fill out a pdf form?
Answered By 0 points N/A #200413
A pdf format is different than normal word files. It is made precisely for the purpose of being not easy to edit. So, the coaching centre gave you a pdf because they do not want you to edit the Questions that they have written. You can fill the form in the below mentioned two ways now:
1. This option involves the use of a scanner and a printer. You need to print the pdf file and then fill it normally, and then scan it and put it inside the computer.
2. If you do not have a printer and scanner, you can use this method, but it is not an option if your coaching centre has protected the pdf. You can copy the whole pdf and paste into word. Now, fill out the form while maintaining the layout. Then, save it as a pdf.  
