syedshaon
Posted on - 08/27/2012
Hey I have one memory card and one pendrive which are not working. There are some important data on those. I've tried different Usb recovery tool to get those data back but failed. Will you please help me to find a good Usb recovery tool?
Thanks in advance
Syed Shaon
Can anyone give information about a good USB recovery tool?
Hi syedshaon
USB Recovery Tool is a software flash recovery utilities. USB Recovery programs and Repair Tools is to recover usb restore, USB download Best Flash Drive recovery tool professional pen drive recovery utility pen drive recovery downloads. Recovery tools is capable to handle all sorts of data loss issues from USB flash drive media.
sara
Hello Syedshaon
I suggest you to use USB Drive Data Recovery software to recover your data. It supports most of the pen drives available in the market. You can download the software from here:
An other tool for recovering your data is Wondershare Data recovery.
It is available for both mac and pc and you can download it from the following link:
I hope that you recover what you lost!
'Bottom line; is a good software. Although this is not a free version but you can use the trial version just to check how it works for you.
You can also try using 'PhotoRec' which is a free software and a very powerful tool to recover data from almost any device. Another free software is Recuva. This is also powerful software.
'Recover My Files' is one of the expensive tools. However, in general most of the file recovery software serve the same purpose, it is important to try different software and which one serves the purpose. If 4 or 5 software failed to restore the data then it is pretty much the memory disk is damage permanently.
