Can anyone give some detail information about Vizio C15 Ultrabook?
The latest product of Vizio is their Ultrabook which is C15 Ultrabook,
Closely related to MAC computers which is made by Apple Company but only difference is that Mac have the only entire white-glove experience which Vizo can’t supplement that drawn the loyalty of the customer to the MAC OS.
Main features,Â
1. All-in-one third generation Intel PCs Used
2. Core dual
3. Quad core i3
4. Core i5 and i7
5. 24-27 available inch
6. 1080 high definition display
7. Also have a subwoofer for entertainmentÂ
Ports,
1. HDMI
2. Ethernet jack
3. 3 USB 3.0Â
4. Single HDMI
5. 1.3 mp camera
6. 128 GB Drive loaded with windows 7 home premium
Vizio also known for its flat panel display and very close to the specification of current windows operating system which is Windows 8.
If you are referring to Vizio 15.6″ Thin + Light (CT15-A1) Ultrabook, it ships with 64-bit Windows 7 Home Premium. It is powered by 1.7 GHz Intel Core i5-3317U processor, 4 GB RAM upgradable to 8 GB max, 128 GB SSD hard drive, and Intel HD 4000 video card with shared video RAM. It comes with 15.6-inch display at 1920 x 1080 native screen resolution.
Vizio CT15-A1 Ultrabook
For connectivity, it supports Wi-Fi 802.11 b/g/n, Bluetooth 2.1, two USB 3.0 ports, HDMI, and headphone jack. It measures 14.9 x 9.9 x 0.68 inches and weighs 3.96 pounds. If you need to install drivers, go to the VIZIO home page or the VIZIO Support. You may be required to enter your product’s serial number or model number to download drivers.
For the pros, it has a stunning 1080p display with an attractive aluminum unibody design, fast SSD hard drive, and includes no bloatware. For the cons, the product has a limited selection of ports and does not support SD card. It also has a short battery life and the keyboard has no backlight.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
