Can anyone give some example of Facebook connect controller changes websites?
I heard about some Facebook connect controller changes websites. I want some effective example of it. Can anyone give some example of this kind of websites?
Best Answer by carpenter harrer
Answered By 0 points N/A #139382
If you are using Facebook Connect in your websites, then people can login to your site using their Facebook profile and can update your website information on their Facebook. Using Facebook connect your site will be more popular.
For using some sites, you may need to register on the site. If that site have Facebook Connect you need not to enter your data .By logging Facebook Connect site can retrieve all the information needed.
Many blogs and sites use the application Facebook Connect including CNET, Family Tree, Vimeo etc.
Answered By 5 points N/A #139383
Hi Cassandrajnorman,
I know of a very good website that has Facebook connect. The site is http://www.cbs.com/. You can allow users to login to your website using their Facebook or twitter account. Take a look at the photo below to preview what is expected of the user.
CBS login
Other good examples of sites that I know are as listed below;
  1. CNN – With CNN, it only has Facebook connect but lacks twitter.
CNN login
  1. Vimeo – The login link for Facebook is shown with the yellow arrow.
Vimeo Login
  1. CNET – Below is a screenshot of the screen that appears when you click on login.
CNET login
Answered By 0 points N/A #139384
The list of websites that use Facebook connect ids huge and growing every time. Take a look at the list inserted below, probably you can find some useful sites over there depending on the area that you need.
These are the most active ones.
Good luck!
