Can Anyone Guide Me Towards Solving My 0x000000c7 Error?
Hi! I recently came across this 0x000000c7 error message while starting my computer. Can anyone tell me what could have caused it and how to fix it?
A) This 0x000000c7 error caused when a kernel timer or DPC is found somewhere inside the memory where it is not allowed. To fix it, you need to update the windows with the latest update by going inside the control panel and search for updates. Then download and install the updates, and after the restart, your error will be resolved.
B) This 0x000000c7 error caused when a kernel timer or DPC is found somewhere inside the memory where it is not allowed. To fix it, you need to go to Device Manager and click on the option of scan for hardware changes, and it will show the device or driver that is causing the health or performance issue in your PC and then, you could fix it.
Notifications
