Can anyone have 4media iPad license code?
I need the 4media ipad license code. I was using the trial version of it and now it is expired because trial days have been ended. I need the help in this regards if anyone help me. I will wait for the reply might be someone having the solution of this problem.
Answered By 0 points N/A #141586
I find this problem hard to solve, but I can suggest you something. If you want another 30 days with the software, delete all content and feel free to download/install from this website:
Kioskea.net | Download | 4Media iPad to PC Transfer
This version works on Windows XP, Windows Vista, and Windows 7. It allows you to transfer videos, music or audio files from your PC onto your iPad. The inverse operation is also possible for any backup. Not only does it transfer your files but it also offers you a simple way to manage them, to edit them and to organize them as you like it. Feel free to tell me if this worked out for you.
